Media Jukebox, версия 8.0.222 Beta...
г. 08:43 ч.
Media Jukebox е виртуален музикален център, включващ CD плейър, MP3 кодер, CD рипър, с помощта на който ще запишете музиката от аудио CD в MP3 формат, софтуер за обработка на плейлисти, ID3 редактор, DVD плейър (за да работи трябва да инсталирате DirectShow 6.1 и MPEG2-декодер).
Какво е новото, спрямо миналата версия:
  • Fixed: Display bar would show up in mini-me display window
  • Fixed: Fade-out stops would take a long time in mini-me
  • Changed: Resize display for bars now optional
  • Fixed: Pasting image would not work if Cover Art directory did not exist
  • Changed: Display bars will not dissappear when the menu is visible
  • Changed: Moved image saving code for ogg format into OGG plug-in
  • Added mouse wheel support for mini-me playlist
  • Added access to MJAutomation object to Metamorphis JScript
  • Changed: Mixer object for Metamorphis moved to MediaJukebox.GetMJMixer
    fuction
  • Added mouse wheel support to sliders in Metamorphis
  • Added OnPlayStateChanged event to Metamorphis
  • Fixed: Go button in interface plug-in was always disabled
  • Fixed: Playlists are not showing up when connected to Music01 Server
  • Fixed: Mini-me would not always come to the foreground when started
  • Changed: Splash screen is disabled in mini-me mode
  • Fixed: State property would not work in Metamorphis
  • Changed: When no aspi dll is detected, MJ will download and install Adaptec's version 4.7 Aspi
  • Fixed: A bug in the BuyButton save/restore rrg file functioning that
    prevented some users from restoring their license
  • Fixed: After a secure ripping failure, if user chose to continue ripping
    it just stalled until cancel was pressed
  • Fixed: Fixed a lot of Metamorphis bugs. Had to rewrite a lot of code
  • Visualization engine natively supports layering
  • Added "OnEquation" to all visualization components
  • Fixed: Changing position of placeholders in Metamorphis skin did not work
  • Metamorphis skin item state in now saved to state.xml
Media Jukebox, версия 8.0.222 Beta може да изтеглите от тази страница7.7Мб.
Споделете тази новина:
Подобни новини
SetCombG.com новини
Още Новини
