MyIE2 0.8.130 Beta
г. 19:21 ч. М. Лазаров- Favicon support. Enable / Disable this options in MyIE2 Options->Tab.
- ALL current IE encoding support. Select from toolbar dropdown button.
- Set background color, font size and transparency(only Win2K,XP) level of collectors.
- New script commands for plugin developer. Check pluginplugin_HowTo.htm for details.
- Can use URL alias, Default search in `Open address dialog`.
- Better download manager support. Select download manager at MyIE2 Options->Download.
- IE BHO type plugin is disabled by default. Add bLoadBHO=1 to plugins.ini [IEPlugins] to enable it.
- "Do Not Load Start Page When Opened by Other Program" setting at `when starting` dialog.
- Links bar missing problem. (Need confirmation).
- Clean history would also clear typed URLs.
- Proxy menu did not updated for localhost.
- When status bar is not visible and tab bar is at bottom, double click on tab bar would not open new tab.
Линкове:
MyIE2 0.8.130 Beta Combo | bg mirror (1.6Mb)
Споделете тази новина:
