· Add Scroll page up/down;
scroll to page top/bottom to mouse action.
· Auto highlight search keywords.
· Search settings dialog.
· IE extension toolbar chevron support.
· Display local file name in favorite search result.
· Hot key for search bar. Ctrl+Shift+F .
· Sort utilities, plugin buttons, Sort group items.
· Support javascript in search bar engine.
· New extend command. m2_search_text: the text in search bar.
· Check for new version at start up.
· Save as group will use tab title as group item name.
· Double click on secure lock of the status bar to show current site's certificate.
· Tab list in collector.
· System Path support in utility setup."$WINDIR,$SYSDIR,$PROGRAMFILES,$DESKTOP".
· Show group members when right click on group menu.
· Customize hide key in general option.
· Show Tray icon and close to tray options.
· Configable appreciation service.
· Multi-language plugin system.
· New plugin found dialog.
· An easy way to switch from 'Options' to 'Setup Center'.
· Better memory management.
· Favorite bar default set to links.
· AddFilter extension function will return false if user select no.
· Show main window from DDE call if it's hide.
· Fixed a bug in restoring default mouse action.
· Fixed ' Delete cache also damage history problem. '
· Fixed ' Plugin bar drop last two button problem. '
· Fixed ' mouse rocker popup context menu problem. '
· Fixed ' User selected tab color would be affected by skin problem. '
· Fixed ' MyIE2's caption was not sticky with tab's sticky name' problem. '
MyIE2, версия 0.9.10...
г. 09:31 ч. Кристиан ДимитровСподелете тази новина:
