Koepi's XviD 1.0.1 build 06.05.2004
г. 14:42 ч.
Нова версия на популярния кодек. Промените са:
- (core) small trellis bug which probably reduced sharpness of the image, but possibly even produced artifacts
- (core) motion estimation buglet slightly reduced b-frame's quality
- (core) 1 fps files failed to decode
- (core) intra coefficients were sometimes not clipped correctly, which might (in theory) produce artifacts (don't worry, noone has seen the artifacts yet)
- (core) if two p-frames were more than one second apart, b-frames in between are not decoded
- (VfW) video was not playable via ICM (mplay32.exe, files embedded in Office applications etc)
- (VfW) calculator did not open many useful audio/subs extensions by default
- (VfW) calculator calculated audio size wrong when given bitrate and length (2.4% eror)
Линкове:
Koepi XviD 1.0.1 (617Kb)
Споделете тази новина:
Подобни новини
SetCombG.com новини
Още Новини
